1.6Hdi Spped Limiter Wiring
Clackers
Unread post by Clackers »
I am looking for some info to enable me to enable the speed limiter function on my Dispatch van its a 1.6Hdi. I have added the stalk and enabled cruise control which works ok. I dont have the correct accelerator pedal as mine has 4 wires rather than the 5 required for the limiter 'kickdown' button.
I have the Bosch EDC316C34 ECU and from what I have found online it seems im missing 1 wire between the throttle pedal and ecu. I have seen this post on the forum viewtopic.php?t=68777 which shows what appears to be a limiter enabled pedal and wiring at each end, Im happy to change the plug at the pedal and run another wire but would like more detailed pinout info on the ECU. can anyone point me to where I can find this?
I did once try subscribing to the servicebox system but found the countdown timer a bit much, I just want to be able to dip in and out briefly without spending a fortune. I have an imported toyota and they have a great online parts catalogue which is free to anyone. Shame Citroen have gone the other way. Anyone know if you can download wiring diagrams for older models anywhere?
I am of course assuming that the vehicle will support all this! Im assuming the limiter should be ok as cruise is working. My van appears to be a fairly basic base model electrically, the old berlingo enterprise on the other hand had many more bells and whistles.
My VIN is VF7**************[VIN obfuscated, can be read by forum staff].
