throttle Pedal Wiring Diagram
tipu2020
Unread post by tipu2020 »
Hello All,
i have recently bought C3 2007 Automatic, RHD, 1.6 , VIN Number VF7**************[VIN obfuscated, can be read by forum staff]. Looks like it needs replacing Throttle pedal to fix fault P0221 however, looks like some work has been done in past and connector to pedal looks bit odd as wires seems to be in different colour and joined together See Attached picture.
I am looking for throttle pedal wiring diagram to confirm and found viewtopic.php?t=62809 , I can see the same wiring however the colour for wire 1378 (Beige) is Blue in my car.
I would really appreciate, if someone can confirm that 1378 should be blue or help me with throttle pedal wiring diagram to ECU and any interconnecting connectors .
Thank you and kind regards,
Tipu2020
x 6945
Re: throttle Pedal Wiring Diagram
Don't worry about the colours so much as the actual connection.
The positions and colours of the wires before the plug are correct - but somebody has changed the plug and used the wires from that plug to join them to the loom at the heat shrink.
So if you focus on the wiring before the joint to the plug, they are in the correct positions:
Pin 1 - White (Blue at the Plug)
Pin 2 - Green (Green at the Plug)
Pin 3 - Blue (Violet at the Plug)
Pin 4 - Violet (Yellow at the Plug)
Pin 5 - Red (White at the Plug)
So to confirm, the wires are in the correct positions.
Connection From Throttle to Engine ECUPin Out and Colours of Throttle Connection Plug
tipu2020
Thank you so Much for quick reply
