207 1.4 mini engine vti
harwoodguy
Unread post by harwoodguy »
sometimes i notice a tick noise from driver side of the engine but only does it every so often
is this normal on theses mini engines or is it a sign that my timing chain is on its way which i thought if it was chain it make the noise all the time and i no eml light
harwoodguy
Re: 207 1.4 mini engine vti
i was thinking to changing vvti solenoid but then it would after do the noise all the time or cause a error so im hoping its not a sign of chain failing its only got 67k and i only owned car for 5mth
FishHo
Unread post by FishHo »
You wont hear the VVTI solenoid , its buried in the cylinder head. Does it happen when its warm , cold , at speed, stationary , varies with speed or engine rpm ? Need a bit more info. 67K miles is 107K Km which would be about right for the chain.
PaulC5
x 665
Unread post by PaulC5 »
We had a C3 with the 1.4 vti engine and that needed a new chain at about 50k miles. It started to give a fault code related to the timing not being right.
GE500
Unread post by GE500 »
My partners 1.6 'Prince' engined Mini, 80k miles, has just had the timing chain problem. The only noticeable symptom was a clatter from the chain area on cold starts which persisted for a few seconds, but it was otherwise running fine. She went for the repair (Cam chain, guides, tensioner and oil pump chain etc) just for reliability. After the work we noticed that the engine is now overall slightly quieter when warmed up.
