Citroen relay van 2017 horn
Marvan1
Unread post by Marvan1 »
horn not working, I’ve changed clock spring, checked horn direct to battery, working, changed steering wheel.
All working on other van. Put everything back still not working. Change fuses etc. help please.
x 1056
Re: Citroen relay van 2017 horn
Unread post by wheeler »
OK its a pretty simple circuit.
Do fuses 3 & 10 in the under bonnet fuesbox have power at them?
Next Relay T03 in the under bonnet fusebox, Do you have 12v at 2 of the terminals? And a switched earth when you operate the horn switch?
The other terminal when applied with 12v should operate the horn if wire 188 is ok.
Marvan1
Thanks. Van was left with a autospark who somehow sorted it.
x 1940
Unread post by Paul-R »
Any idea what he did? What does it say on the bill?
Marvan1
Haven’t a clue. It was fixed as part of a warranty claim.
