Removing injector fuel pump
Slick8
Unread post by Slick8 »
Peugeot partner 1.6hdi 2006
I've removed the bracket at the back of the pump(4 bolts) and the nut and the bolt on the side/front however you look at it. So I'm sure I've removed all necessary bolts/nuts but it seems pretty solid in still, there's a very slight bit of movement in the pump but seems like it's still bolted in somewhere?
Any ideas?
x 1059
Re: Removing injector fuel pump
Unread post by Rp0thejester »
You sure it's not just a very tight seal holding it in?
Slick8
Rp0thejester wrote: 26 Jun 2023, 20:14 You sure it's not just a very tight seal holding it in?
Could be, I'll try a bit more force.
