Peugeot partner 1.6hdi 2006
I've removed the bracket at the back of the pump(4 bolts) and the nut and the bolt on the side/front however you look at it. So I'm sure I've removed all necessary bolts/nuts but it seems pretty solid in still, there's a very slight bit of movement in the pump but seems like it's still bolted in somewhere?
Any ideas?
Removing injector fuel pump
- x 1064
Re: Removing injector fuel pump
You sure it's not just a very tight seal holding it in?
Champion of Where's CitroJim
Slick8
Could be, I'll try a bit more force.
