Engine fault repair needed.
Nawelum
Unread post by Nawelum »
First post on here so correct me if I am doing anything wrong!
So over the past 2 months my Citroen C4 1.6 2012 has the message ‘Engine fault repair needed’ and the Amber engine light appears on the dashboard. I notice this only comes on when I am gaining speed or accelerating. It will go off after a day or two then come back on again once I hit the motorway or accelerate anywhere else. Will probably have to get the garage to diagnose it anyway but wanted to check first if anyone had any idea what could be wrong and what the rough cost would be for repair.
x 1077
Re: Engine fault repair needed.
Unread post by Rp0thejester »
Well, first of all, welcome!! Are you accelerating uphill,downhill? Do you have a dpf fitted to that vehicle?
x 1496
If it's diesel, when was the fuel filter last changed?
x 2358
Unread post by MattBLancs »
As others have said, could be 1.6 HDi (DV6) diesel or 1.6 16v petrol (TU) - and obviously quite different potential faults between the two! :)
Nawelum
Hey,
Thanks for the responses already! It’s happening when I’m going uphill and it’s a diesel, for the fuel filter being changed I’m not 100%. In saying that I had another message come up about a particle filter! I should really get this booked in instead of putting it off
PaulC5
x 698
Unread post by PaulC5 »
Since the engine light has come on a low cost code reader may be good enough to read the fault code and indicate what could be wrong. It will be cheaper than paying a garage to do this. As an example of one that also does some live data and freeze frame data when the fault happened https://www.gendan.co.uk/product_FXNT200.html It could be something simple such as the MAP sensor is bunged up or the dpf is blocked.
Nawelum
Thank you I’m gonna get one of those ordered and hopefully get to the bottom of it! Appreciate the help all thanks a lot
