Good evening
I am really struggling to locate a supplier of the 11 mm bolts for the Bosch callipers It looks like as widely discussed on here that Pug parts are not standard and what ever available was fitted
Many Thanks
2004 Partner Escape/Tepee Bosch calliper bolts
DEVON DOGG
DEVON DOGG
Re: 2004 Partner Escape/Tepee Bosch calliper bolts
Update
I found them and it is the calliper slide pin bolts . You can only buy the kit for £49 a side for Peugeot with the pins
but
If you look for a Citroen Berlingo Bosche kit you can get them for £14 for both sides
So I replaced the pins and put a shot grease in each one with new bolts
but
- x 1059
So did they fit correctly?
Champion of Where's CitroJim
DEVON DOGG
- x 1059
So money grabbers tried it again!!
