2004 Partner Escape/Tepee Bosch calliper bolts
DEVON DOGG
Unread post by DEVON DOGG »
Good evening
I am really struggling to locate a supplier of the 11 mm bolts for the Bosch callipers It looks like as widely discussed on here that Pug parts are not standard and what ever available was fitted
Many Thanks
DEVON DOGG
Re: 2004 Partner Escape/Tepee Bosch calliper bolts
Update
I found them and it is the calliper slide pin bolts . You can only buy the kit for £49 a side for Peugeot with the pins
but
If you look for a Citroen Berlingo Bosche kit you can get them for £14 for both sides :lol: :lol:
So I replaced the pins and put a shot grease in each one with new bolts
x 1072
Unread post by Rp0thejester »
So did they fit correctly?
DEVON DOGG
Spot on
x 1072
So money grabbers tried it again!!
