C3 puretech EB2F 1.2 vt1 2013 oil baffle loose ??
mamba76
Hi all. Im doing a rebuild on this C3 1.2 VTI PSA engine and noticed before replacing the sump that theres a plastic oil baffle sitting below the crank. It doesn't seem to be fixed in any way and the dealer says there are no fixings for it. It doesn't seem to actually touch any moving parts but it does move around. This just seems a bit wierd. Is this normal ?
- x 2362
Re: C3 puretech EB2F 1.2 vt1 2013 oil baffle loose ??
Sounds odd to me. As a comparison, an older (2.0) EW10J4 engine: mild steel "windage tray" is robustly held in place with 4 M8 bolts.
Is there any chance it's only loose whilst the sump is off - and it's pinned in place once that is installed?
mamba76
Na sits above it and cant be got at without splitting the crank case. It look strategic. Guess ill find out when i eventually start the car.
mamba76
heres a link to the guide Im using. Still can't acertain from this if the plastic oil baffle is supposed to be fixed or not
https://www.nomaallim.com/psa-eb2-engin ... moval.html
