Nemo broke down with automatic transmission
ohspecial1
Unread post by ohspecial1 »
Hi
Folks
Nemo 2010 broke down with the semi auto on a dual carriageway today
With automatic transmissions fault
Managed to get going again in manual mode
its off to garage for diag tommorow any ideas
Sounds expensive but only has 29k miles
x 6955
Re: Nemo broke down with automatic transmission
These are nightmare transmissions and can be expensive when they go wrong, but without a fault code I can't really help you. Once the garage have it they run a diagnostic, they should be able to advise, but Nemos are essentially FIAT Fiorinos, as is the Peugeot Bipper.
ohspecial1
Hi
Well had diag today
But wont get the codes till next week
all i know is it got 5 codes but they cannot tell if old or new
2 on auto trans
1 on high pressure (something to do with why it stinks of diesel but have been told its not the injector seals
x 6955
There's no automatic transmission on the Nemo. You will have a manual gearbox and clutch, but with hydraulic actuators to do the gear shifting and operate the clutch for you. So these are referred to as piloted gearboxes, but they are not automatics in that they don't have a torque converter.
If you have the codes I can give you some idea. Pop them up with your VIN (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff) when you have them.
ohspecial1
Engine management
P1394 Gearbox ecu cruise control speed limiter off request from the gearbox
1612- Engine immoblizer error reading or writing immoblizer code
1199 Fuel high press regulation anti-out of fuel stratgy
Trans
u1213 Information sent by the abs ecu coherence
po750- Gearbox- the gear doesnt not engage
Bsi
c019 Comfort/bodywork can(can b) communications impossible not characterized
x 6955
You forgot the VIN too.
ohspecial1
VIN
ohspecial1
its going to citroen diag on thursday
Nearly collapsed when told £120
Guy reckons clutch failure but im thinking thats an old code
x 6955
Unfortunately, there is no further info on these codes, and some you have provided are not shown as valid. £120 is a standard Citroen diagnostic charge for up to an hour inc. VAT - but at least you are taking it to the official dealer, so won't waste time going round in circles as a lot of garages won't touch these gearboxes.
P1612: Coded anti-start : Error reading or writing the Coded Engine Immobiliser code
P1199: Fuel high pressure regulation : Lack of fuel prevention strategy
U121300: Information fault emitted by the ABS ECU: Coherence
P075000: Gearbox fault - The gear does not engage: Not characterised
ohspecial1
Hi
Went back to garage who done diag as they work on the same estate
Plugged the maxxis in and only got 1 code now
BSI C019
They are saying give the car a good run as i only do about 30 miles a week
ohspecial1
went to Citroen faults
C019 U0019 C019 Network of area of the control DOG bus of information, bus of low speed
Could this be it
vmguru
Unread post by vmguru »
How did you clear the P1612 EEPROM memory (coded immobiliser) error message? I'm getting a similar situation with my van
