Heating not working c4 grand Picasso 2012 1.6diesel
bbfn2001
Hi was wondering if someone could advise, I have only the smallest amount of of hot air blowing, feels more cold than anything, I have replaced the thermostat housing, the heater matrix, bled for airlocks, but still the same what would be the next step thanks
- x 6950
Re: Heating not working c4 grand Picasso 2012 1.6diesel
How did you bleed the system - there are procedures for doing this after coolant replacement.
bbfn2001
Not sure was done by mechanic
- x 6950
Well all I can tell you is that it has to be bled correctly in order to properly bleed the heater matrix.
bbfn2001
Could you point me the direction of how this is done(the procedure) thanks
- x 6950
I can but you'll need to upgrade your membership to access the resources / procedures:
In the procedure below it is the identical process on your engine, just follow the part under de-gassing for non-Euro 6 engines.
The guide is for the complete draining and refilling of the cooling system, so you'll be able to see if any steps were not completed.
viewtopic.php?t=64036
If you wany to upgrade your membership which will also provide you with official part number requests for up to 2 years, follow the links below:
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, I already have your VIN.
bbfn2001
