Citroen C5 X7 new upper rear door hinge
turbovette350
Unread post by turbovette350 »
Hi, Iv'e just fitted a new rear upper door hinge, the one with the box of tricks attached. I replaced it because the door wouldn't stay open now it's too stiff/notchy, does it need to be lubricated?
thanks Paul
x 6950
Re: Citroen C5 X7 new upper rear door hinge
I'd use some marine grease and lightly coat the latch, open and close the door a few times and that should help it.
Do all the other latches like this too. Water gets in these and starts rusting the internals, so I also greased the whole thing.
turbovette350
thanks for the info but how do I get the grease in?
x 6950
I just greased the whole thing and tried to cram as much into the seam as I could.
If you want to see what's inside, have a look here at a teardown, though I'm not so sure you'd want to remove disassemble it now! :-D
turbovette350
considering putting a small hole in the top and pumping oil/grease inside and sealing with a rubber bung.
I love Mativoire best colour for a C5 especially with the grey leather interior.
x 6950
That was what I had on my X7, great combination.
