Peugeot Boxer injection pump bracket
Brendan the first
- New User
I am totally lost here , can't find where or how to open a post in forum . Staring here for an hour . What do I do ? I need a part for my Peugeot Boxer symbol camper 1999 , 1.9D . An Injection pump bracket . HAve searched everywhere , not being produced any more I'm told . Sorry if posting this in wrong place . I'm in Ireland .
- x 8063
Re: Peugeot Boxer injection pump bracket
Hi Brendan and
In order to get part information you will need to make a donation to the forum of a minimum of £10 but it will cover you for parts info for 2 years. You will find full details if you follow this link: viewtopic.php?p=685750#p685750
Once you have sorted that have a look round the forum from the board index above, there are many things under discussion and you will find information, entertainment, education and even banter!!
- x 1056
sound like he has already tried the dealer & been told the part number is no longer produced??
Have you tried breakers?
- x 6954
Probably right.
If the dealer has already told you it's not available then you'll need to look elsewhere as Wheeler mentions like a scrappy.
- x 1438
Would that happen to be the same engine (and bracket) as this C15 which looks likely to be scrapped? viewtopic.php?t=74299&p=752699#p752699
- x 2316
I think your 1999 is on the change over between XUD and DW8 (that C15 is a DW8)
Can you post some pictures? and should be able to identify your engine. Inlet manifold is the easy to spot difference between the two. (And glow plug position if inlet is off out the way)
- x 1056
I don’t believe the DW8 was ever used in the Boxer.
