Blower Motor - Am I missing something?
Rosco88
Unread post by Rosco88 »
Morning All!
The blower on my 07 Mk1 C4 failed this week, i have had it out at the weekend, checked and replaced fuses and still no joy.
At one point during testing (fan out + plugged in) i turned the car on and the fan switched on for about a second then went off again - which makes me believe it is not the fan - or the power.....
I have changed Fuse 11 on the below
and fuse 11 on the below
I have read about failing relays and changing the entire fuse board as well as the heater resistor, but was hoping for a little more guidance before spending money.
( i appreciate diagnosis over the internet is a little difficult)
x 6945
Re: Blower Motor - Am I missing something?
The most common cause for the motor failing (apart from the blower motor itself) is the Blower Motor Control Module. When these resistor controls fail, either the fan will remain on full blast or nothing.
If this is the case, then which type you need, will depend on the specific vehicle and type of air conditioning you have (simple or automatic).
If you need an original, genuine part number or part diagram, and can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
Rosco88
Hi Marc,
Thanks for the response.
The aircon unit in the car is this one (only pic i can find online)
and the blower motor is this
and form what i can read it says the Resistor Pack is part of the front panel? So its potentially a new unit job?
x 6945
No, it won't be there. The Blower control module is located to the side of the heating unit, not in the air conditioning control panel. You'll need to remove the passenger lower right side footwell trim to get to it.
x 1055
Unread post by wheeler »
The heater speed controller/resistor unit is on the left side of the heater box, remove the glovebox for access. Its a kind of bayonet fitting where you do a quarter twist anti clockwise to remove it. Plenty of new aftermarket ones on ebay for under £20 inc postage.
Cheap enough for a punt but be aware heater problems on early C4's can be caused by the under bonnet fusebox, There is a big (non replaceable) relay in there that can play up.
