C5 X7 rear tailgate strut oil leak
Argos69
x 51
Unread post by Argos69 »
Hi again,
"Her" latest challenge is oil leaking from the driver's side tailgate strut.
The tailgate is the "motorised" variety, which basically means you stand in the rain waiting for the stupid thing to open or close, instead of just opening it the old fashioned way.
Anyhow, I've not found anything after a search, so is this a "rare" issue?
Question.....
Is it (economically) fixable, or can I entertain the notion of "doors to manual" and convert it to manual? At the risk of pre-empting the answer to that last question, would it be a case of New Struts, New Lock, New keeper, then Lexia? :?
As ever, all advice warmly welcomed and appreciated.
Thank you :-D
2010 Land Rover Freelander 2 HSE Automatic
2013 Citroen C5 Tourer 2.2HDi Exclusive
2017 Citroen Berlingo Multispace Flair 120 Gone!
2012 Citroen C5 Tourer 1.6HDi 6 Speed (sort of auto!) Gone!
2012 Citroen Berlingo Enterprise 1.6HDi Van Gone!
2001 Range Rover 4.6 Vogue Gone!
x 6945
Re: C5 X7 rear tailgate strut oil leak
I think I responded to a recent post from another member on the motorised strut issue - although his was not leaking, but to reiterate here, the motorised struts are about £190 each inc. VAT new. The manual tailgate have different struts, which appear to be a different size and the bolts are different too. There are quite a few different parts between the versions.
I suspect that raising or lifting it when in 'commanded' mode can mean working against the system so can weaken it. Or it may just have developed a leak, but this is the first time I have heard of a leaking strut on the X7 with motorised tailgate.
Argos69
x 51
Hi Marc and thank you.
Yes, it's leaking oil. Dried it off yesterday and saw a little fresh oil today.
Still opens but needs a slight "helping hand" to start it off.
Anyone know if it's an easy replacement or a "stinker" of a job?
It has a thick-ish black tube coming from the end of the strut. Is that electrical, hydraulic :? or whatever?
I'm too busy with work to get the socket set out this week, but I shall dig a little deeper when I have the time.
Thank you once again.
x 6945
It is hydraulic and electrical.
Please check your PMs
x 6945
x 2341
Unread post by MattBLancs »
GiveMeABreak wrote: 13 Apr 2023, 23:22 Here you go Graeme:
C5 X7 Motorised Tailgate Strut Replacement
Hi Marc,
It might be worth also (perhaps as footnote to that excellent guide?) Be useful to put a link to this:
viewtopic.php?t=71516
Essentially, if the boot strut ball joint on the body is unscrewed and the captive nut inside the D pillar is loose, it would be free to drop down and you'd have a whole world of pain from that point on! It was bad enough "creating" an access hole to then blindly waggle a ring spanner through to just re-tighten the nut!
Hopefully my own experiences were a freak unusual failure (and I suspect perhaps result of previous owner / maintainer attempting to drive a somewhat rusty ball joint bolt thread into the captive nut and the increased torque shearing the nut of inside. At which point they just left it loose! :evil: )
x 6945
I have done now Matt, thanks for the reference. :wink:
x 6945
Hi Graeme
As per your PM, here are the parts for the motorised Struts:
(6) Motorised Tailgate Strut (Left), part: 8731R5, £214.27
(6) Motorised Tailgate Strut (Right), part: 8731R4, £214.27
Direct from Citroen inc. VAT.
Argos69
x 51
How time flies!
I can only apologise, as the original poster of this thread, for despite the help, not doing the job and letting nearly a year slide by!
I noticed the other day that the strut "oil leak" I originally spotted and which appeared every couple of days, has now dried up. It looked like oil and kept appearing, but now nothing.
So where am I now?
I've carried out the procedure to disable the oversensitive "economy mode", so the only issue I'm left with is that the tailgate will not lift from the closed position without a bit of help to get it started on its way. It then behaves itself, closing and locking as normal.
No Diagbox errors of any kind.
I'd thought of replacing the strut/s but I don't suppose there's an oil reservoir that may be low and needing topped up somewhere is there?
Every fault with this car has been an absolute swine involving parts prices akin to those of a Eurofighter, so this will no doubt be the same, BUT I like the darned thing and the level of comfort is absolutely great.
I heard anecdotally, that the motorised tailgate can be disabled in Diagbox. Does this mean a "normal" tailgate results or simply a "dead" tailgate that won't stay lifted?
Keep up the good work and thank you for any help.
Argos69
x 51
I hate people asking for help and then never posting the final result, so we all know what actually happened.
Admittedly, in this case, it has taken so long, this post has started drawing it's pension! Sorry for that. It's taken until today to finally fix it! Yep, that's 2 years and 5 months - ish!!!! Nobody can say it was a rush job!
I've had so much to do on houses and cars, including rebuilding the passenger side of this car after a hit 'n run and because we live in the middle of nothingness, had to wait until we had a second car, in case I stuffed this one up, trying to fix the tailgate.
I took off as much trim from the tailgate as possible, then sliced into the convoluted wiring cover at the top left, to expose the wiring.
I'd hoped for a nice obvious broken wire, but they were all solid, although two had the insulation crumbled away - maybe they were touching sometimes? Also there was water in the wiring bundle. Anyhow, cleaned, dried, insulated, then bound up in self amalgamating tape, before putting it all back.
Not 100% hopefully, but fear ye not! The electric tailgate now behaves exactly as it should AND the erratic rear wiper is now back in action. Had to laugh at myself though. At first the rear wiper did nothing, then later on I remembered I'd taken F1 fuse out of fusebox C, two and a bit years ago! Ooops! Refitted the 15Amp fuse and we have a rear wiper.
So the car with the seemingly endless list of "jobs to do", has a couple less. At this rate, in another few years I'll be completely happy it's all done!
wurlycorner
x 271
Unread post by wurlycorner »
Well done for coming back and updating the thread - thanks
Iain
CX DTR T2 Safari (silver)
