Hi everyone, Can anyone help please:
My 2012 (62 reg) C4 grand Picasso is showing ABS, ESP, and parking brake fault intermittently. Recently I changed the rear brake disk and calipers (as it was very Low). But the problem started way before that. The electronic parking brake can be engaged and disengaged manually by pressing the brake button. I also can hear the hand brake motor working when pressed. When the service light on the hill assists won't work as well.
The thing is when the car is parked on a level surface, the service light and fault lights won't switch on. But when the car is parked on a slopy/inclined road the error codes will come on.
I did a fault reading using Diagbox and got codes C1550 and C1219 U1219.
VIN - VF7**************[VIN obfuscated, can be read by forum staff]
Please see the attached Daigbox error reading and please help with what needs to be done to resolve these issues.
Many thanks,
2012 C4 Grand Picasso Abs, esp, parking brake faults showing
Abi08
Reason: Corrected Fault Code from C1219 to U1219
- x 1493
Re: 2012 C4 Grand Picasso Abs, esp, parking brake faults showing
Split this off into a separate topic as yours is a different system. It says cable fault, but not sure what that means, is one of them broken or not attached?
Abi08
Hi Richard,
I checked both wheels and cables, but all look fine. no loose or broken cables.
- x 1493
Can you clear the faults? If you actuate the handbrake, do the cables pull up?
Abi08
I cleared the faults twice, but when I park the car on a slopy/incline road it will come back again.
- x 6945
In light of the latter answers. I've cleaned up the thread to remove the irrelevant info and responses.
U1219 has no further detail: Communication with the Electric Handbrake ECU: Value received incorrect.
* Switching on of the warning lamp and/or warning message :
"a" : Electric parking brake fault warning lamp
"b" : Electric parking brake warning lamp
"c" : Service warning lamp
| Fault Code: | C1550 |
| Description of Fault: | Brake cable faults. Cables frozen or problem with calipers.
| Conditions for Fault to clear: | Application and release of the electrically-controlled parking brake successful. |
| Downgrade Modes whilst Fault is active: | Deactivation of automatic mode The electrically-controlled parking brake completes the application taking place at reduced speed and only authorises release Switching on of the warning lamp and/or warning message: *Warning lamp (see picture and reference below this table) - "a" : lit - "b" : On for 10 seconds after the request for application - "c" : lit |
| Symptoms: |
| Suspect Areas: |
