Citroen C5 Estate tailgate microswitch
charlestipper
Unread post by charlestipper »
Hi.
Had a few problems with tailgate on 2007 C5 not opening in past and always been due to broken wires, so fixed relatively easily.
However, it seems that the microswitch has given up the ghost now. How the heck do you remove it from tailgate? can't see anything obvious. Also, which part is it for the MK1 model estate, please?
Still able to open from inside using the old small screwdriver solution.
Any advice gratefully received! Many thanks in advance.
Bas
x 6946
Re: Citroen C5 Estate tailgate microswitch
Maybe worthwhile searching the forum using the advanced search to find some topics on this, like this as one example:
https://www.frenchcarforum.co.uk/forum/ ... 92#p685792
However, if you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future part number requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
A response to your question by a Forum Admin requiring parts or additional information requires you to have made a current contribution (£10 min.) to the Forum.
To Upgrade Your Membership & Donate Click Here
For Further Information About Vehicle Parts and VIN Numbers Click Here
