My last BX estate used the rugger ball front spheres.
My current TZD is a little confusing.
N45388 looks suitable but the 400cc GTI sphere is listed by GSF as being right.
BX DIY tells me that estates use the 500cc sphere.
Jon, what do you think?
The right sphere?
oilyspanner
Jon
jeremy
tomsheppard
Jon
can't remember it, not at work, have a look at the sphere table at http://www.gsfcarparts.com/downloads/sphere_table.pdf !!
mark_sp
Hello Tom
The spheres fitted to the TZD front are the GTi spheres and this is correct. I fitted replacement spheres all round shortly after aquiring the car.
My previous BX was an early 1.9TRS and this had the large volume front spheres. The front of this car was considerably softer than the estate (but the rears felt similarly soft - can I say that ?) but the trade off was a very wallowy ride even at relatively low speed.
The TZD with correct spheres gives a far softer ride than the Xantia I now run which is TD fitted with NON TD spheres.
One final point is that you may also be disappointed if you fit the larger volume spheres as (this may be a point of contention) I believe that the current large volume spheres are not as the originals, that is that the damping is not as soft as the original Cit spheres of the 1980's.
good luck
Mark
good luck
Mark
tomsheppard
