Going to set to with this job, this post will get pictures added later, I'll take snaps as go along and add them in later.
So, wet carpet on passenger side, slight sweet smelling a touch "sticky" between the fingers = coolant.
Matrix replacement isn't full dashboard removal task thank goodness. So I'm guided by a video Huskyxantia kindly found for me
Added complications Vs the video, posh 206 (GTi HDi) has CD changer in glove box. Also is. DV6 with air filter housing and other stuff rather in the way. Digging towards the coolant manifold at same time will generally be is the same direction, so hope both at same time is efficient way forward.
