407 hdi 2.7 - wiring diagram / colours for alternator and compressor
407
x 22
Unread post by 407 »
Hi
I've managed to mangle the brittle connectors to my alternator ( 96 571 296 80 bosch 180 Amp) and air cond compressor (9800849780 SD7C16).
Is there a wiring diagram / harness loom pics that show which wires go where and wire colours (just in case) plus any relays / fuses (if any)
regards
x 6955
Re: 407 hdi 2.7 - wiring diagram / colours for alternator and compressor
Ignore colours - they can change, focus on the wiring codes which are repeated every few inches.
Compressor
2 Pin Black Connector
Pin 1: 8058: Compressor Valve Control
Pin 2: M802A: Earth 802
2 Pin Yellow Connector
Pin 1: 8060: Compressor Control
Pin 2: M802B: Earth 802
Alternator
Alternator (1030)
Pin 1: 1087: Alternator excitation command
Pin 2: 104 : Alternator charge info
B01: battery +
x 22
thanks as always
Mark
407
x 22
One additional question
I take pins 1 and 2 on the female connector are Pin 2 left and pin 1 right when the retaining clip is up the top and looking at the connector
I can vaguely see the numbers in side the old connectors but the replacement are virgin
x 6955
I'm not sure that's correct from what you are showing in the above diagram - you are reversing them as far as I can see, but without being there and with site of the actual connectors I couldn't be certain.
x 22
some pics which support my version on pin numbering on the female (female spade connectors) plug
Some examples
1. Air compressor clutch - The yellow plug on the compressor clutch is the male one (male spade connectors pins stick out)
The green/yellow wire is M802A (goes to earth point E802) and so Pin 2 is on the top.
So if you slide the female connector black pic #1 into pic #2, pin 2 is on top :)
2. Alternator wiring pic, the white wire is 104 (pin 2) and the yellow is 1087 (pin 1)
regards
x 6955
Yes, I can see they've made it even simpler by having sideways facing connectors :-D Whatever works, but you always have the other end of the wire to check against that connection. Best of luck.
