Peugeot 307 2.0 HDI 2001 remote key problem
Rajko
Unread post by Rajko »
Hello everyone
    I have a problem with remote unlocking.
    1. I paired the key
    2. when I click the unlock or lock button, I only hear the relay clicking but nothing happens, the car does not respond.
    PEUGEOT 307 2.0 HDI 2001
    can you help me ?
    ozvtr
    x 246
    Re: Peugeot 307 2.0 HDI 2001 remote key problem
    Unread post by ozvtr »
    The relays in the BSI are shi...not good. The most likely answer is that the contacts of that relay are burnt out, but the relay still works, fairly common.
    I am not sure if they were using a "modern" BSI in 2001? If so, the BSI consists of 2 circuit boards. 1 controller board and 1 relay/fuse board.
    The 2 boards can be pulled apart and either the relay replaced or the whole relay board replaced from a "donor" BSI.
    Replacing the BSI is not really an option. :-D
    Another option is the fuse or fuse holder being damaged?
    liquidhandwash
    x 22
    Unread post by liquidhandwash »
    I have a similar issue so will be watching. Also some time ago I had a problem with the central locking, would lock on the key not the remote, but would just unlock a second later. It was a broken wire inside the driver's door jam.
    x 1938
    Unread post by Paul-R »
    ozvtr wrote: 04 Mar 2023, 01:52 I am not sure if they were using a "modern" BSI in 2001?
    If it's like the Xsara then you can tell by the switchgear on the steering wheel. The early type has the radio controls on the wheel, the later type has a separate stalk.
