C5x7 138bhp 2.0 HDI won't start after timing belt change
darbuck
- x 289
Hi All, I changed the timing belt on the car and now can't get it to start. I couldn't lock the flywheel because I couldn't find the hole on the flywheel even with the starter removed but lined it up with the nubbin on the block. I like the idiot I am rotated it without the harmonic balancer. It won't start now it turns over fine.is it possible it's 180 out because of not using the harmonic balancer.
Darren
- x 6947
Re: C5x7 138bhp 2.0 HDI won't start after timing belt change
darbuck
- x 289
Hi Marc as best as I could apart from locking the flywheel and as I said without the harmonic balancer in place. Thanks for that by the way.
Darren
darbuck
- x 289
I did change the crank sensor because the housing was cracked. I might try the old sensor In it.
Darren
