C5 (X7) DW10BTED4 (138) Timing Belt Replacement
Guides on how to approach the more common problems experienced by our members.
Please don't post in this forum but link to the threads here where necessary.
Anyone wishing to create a howto please submit to a mod or admin for inclusion here. Subject to being edited.
x 1730
Post by GiveMeABreak » 29 Jun 2019, 13:06
This is a guide on how to replace the Timing Belt for the DW10BTED4 engine only
Preliminary Work: Remove the Ancillary Drive Belt
Recommended Tools:
[1] Dynamic tensioner compression lever (-).0188-Z.
[2] 4 mm diameter pin (-).0188-Q1.
Removing
Put the vehicle on a hoist.
Remove:
  • The front right wheel
  • The front right mud-shield
CAUTION: Mark the direction of fitting of the ancillary drive belt if it is to be reused.
Compress the dynamic tensioner (1) in the anti-clockwise direction ( as "b"), Using tool [1].
Peg the dynamic tensioner (1) at "a", Using tool [2].
Remove the accessories drive belt (2).
ESSENTIAL: Check that the roller (1) turns freely (no play or tight spot).
Refitting The Ancillary Drive Belt
Refit the ancillary belt (Observe the following order):
  • Accessories drive pulley
  • Compressor
  • Alternator
  • Roller Tensioner
CAUTION: Make sure that the accessories drive belt is correctly positioned in the grooves of the different pulleys.
Support the dynamic roller tensioner (1) ( as "b"). Using tool [1].
Remove the tool [2].
Progressively decompress the dynamic tensioner to tension the accessories belt.
Refit:
  • The front right wheel, Tightening to 10 ± 1 daN.m
Removing / Refitting the Timing Belt
Recommended Tools
Tools C.PNG (60.72 KiB) Viewed 82 times
[1] flywheel locking tool (-).0188-Y.[2] camshaft gear setting rod (-).0188-M.[3] flywheel stop (-).0188-F.
Tools DF.PNG (47.19 KiB) Viewed 82 times
Tools F.PNG (79.4 KiB) Viewed 82 times
[4] pinion centraliser (-).0188-AH.[5] Dynamic tensioner compression lever (-).0188-Z.[6] belt clamp (-).0188-AD.
Removing
CAUTION: After switching off the ignition, wait 15 minutes before disconnecting the battery (To ensure that the learning patterns of the various ECUs are stored in memory).
  • Remove: The upper battery protector.
  • Disconnect the battery.
Remove:
  • The front right mud guard
  • The protective panel under the engine
  • The accessories drive belt, Using tool [5] (see procedure at beginning of post)
Remove:
  • The oil sump soundproofing (6)
  • The 4 bolts (3)
  • The lower stabiliser bar (5)
Loosen the clips (1).
Release: The air hose (9).
Remove:
  • The bolts (/)
  • The air inlet resonator (8)
  • The bolts (2)
  • The impacter (4)
Disconnect the connector (Engine speed sensor ) ( as "a").
Unfasten and move aside: The electrical harness (10) ( as "b").
Release The fuel supply and return piping .
Remove:
  • The pulley cover (14) (according to equipment)
  • The 2 bolts (11)
  • The nut (13)
  • The top timing cover (12)
CAUTION: It is essential to turn the engine clockwise by the crankshaft pulley bolt.
Peg:
  • The flywheel (/)( as "c"), Using tool [1]
  • The camshaft pulley (15), Using tool [2]
Line tool [3] up with the flywheel; Use: The impacter fixing bolt (4) with the appropriate nut ( as "d").
CAUTION: The target (18) must show no trace of damage and no magnetic source must go near it; If this is not the case, the engine speed fibre ring (18) will need to be replaced.
Remove:
  • The bolt (19) and its spacer
  • The crankshaft pulley (20)
  • The engine speed sensor target (18)
  • The 3 bolts (17)
  • The bottom timing cover (16)
  • The (21) bolt
  • The engine speed sensor (22)
Retain the tensioner roller (23) in its position using a 6 sided Allen key ( as "e").
Slacken the bolt (29).
Turn the dynamic roller tensioner (23) clockwise until the timing belt (24) is not tensioned ; Using a 6 -sided wrench ( as "e").
Remove: The timing belt (24).
Check
Check that the following components rotate freely (Absence of play and points of resistance):
  • Timing belt dynamic roller tensioner (23); Retighten the bolt (29) (if necessary)
  • Roller tensioner (27)
  • Coolant pump gear (25)
Remove:
  • The (29) bolt
  • The dynamic roller tensioner (23)
  • The (28) bolt
  • The tensioning roller (27)
Check:
  • The condition of the seals of the dynamic tension roller (23) and reel (27)
  • The absence of traces of oil leaks on the various seals and on the crankshaft and camshaft ring seals
  • The free range of movement of the crankshaft pulley (26) on the key
CAUTION: Replace any defective parts.
Refitting
Refit:
  • The (28) bolt; Tighten to 5,6 ± 0,5 daN.m
  • The (29) bolt; Without tightening it
CAUTION: It is imperative to replace the timing belt (/).
Diagram A
(30) Index of the dynamic roller tensioner (23).
"A" Dynamic roller tensioner (23) at minimum timing belt (24) tension.
"B" Dynamic roller tensioner (23) at maximum timing belt (24) tension.
"C" Dynamic roller tensioner (23) at nominal timing belt (24) tension.
Preliminary Tension
Centre the crankshaft pulley (26) on its key, using tool [4].
Check the position of the roller tensioner (23) ( as "f").
Position the dynamic roller tensioner (23): At minimum tension (See diagram "A").
Fit the timing belt (24) to a third of its width (Span of the belt correctly tensioned) (In the order shown):
  • On the camshaft pulley (15); Moderately tighten; Using tool [6]
  • On the roller tensioner (27)
  • On the crankshaft pulley (26)
  • On the water pump pulley (25)
  • On the dynamic roller tensioner (23)
Remove the tool [6].
Fit the timing belt (24) over its whole width (In the order shown):
Position the dynamic roller tensioner (23) : At maximum tension (See diagram "B").
Tighten the bolt (29) to 2,1 ± 0,2 daN.m.
Remove the tool [4].
Refit:
  • The bolt (19) and its spacer ; Tighten to 5 ± 1 daN.m
Remove the tools [1], [2], [3].
Turn the engine 4 revolutions.
Check the position of the timing belt (24).
Final tension
Peg:
  • The flywheel (/)( as "c") ; Using tool [1]
  • The camshaft pulley (15) ; Using tool [2]
Line tool [3] up with the flywheel ; Use the fixing bolt of the impacter (4) with the appropriate nut ( as "d").
Remove:
Position the dynamic tension roller (23) at nominal tension (See diagram "C"); Turn slightly in a clockwise direction.
CAUTION: If it goes past the index (30) repeat the preliminary tension operation.
Retighten the bolt (29); to 2,1 ± 0,2 dan.m.
CAUTION: Coat the bolt (21) with threadlock LOCTITE.
Refit:
  • The (21) bolt; Tighten to 0,7 ± 0,1 daN.m
  • The 3 bolts (17); Tighten to 0,5 ± 0,05 daN.m
  • The new bolt (19) and its spacer
Tightening procedure: bolts (19) - spacer:
  • Pre-tightening to 7 ± 2,5 daN.m
  • Angular tightening to 62 ± 3°
CAUTION : It is essential to turn the engine clockwise by the crankshaft pulley bolt.
Check the position of the timing belt .
Check the position of the index (30).
Refit:
  • The nut (13) ; Tighten to 0,5 ± 0,05 daN.m
  • The 2 bolts (11) ; Tighten to 0,5 ± 0,05 daN.m
Reposition:
  • The fuel supply and return piping
  • The electrical harness (10) ( as "b")
Connect the connector (Engine speed sensor ) (22) ( as "a").
Refit:
  • The impacter (4)
  • The bolts (/); Tighten to 4 ± 0,6 daN.m
  • The bolts (/) ; Tighten to 0,8 ± 0,1 daN.m
Reposition: The air hose (9).
Re-tighten: The clamps (1) to 0,35 ± 0,03 daNm.
Refit:
  • The accessories drive belt using tool [5]
CAUTION: Perform the operations to be carried out following reconnection of the battery:
BSI Rest / Battery Disconnect / Reconnect Procedure
Reconnect the battery.
Refit: The upper battery protector.
