Fault code P2191 RCZ
tomlfc
Got a 2013 1.6 RCZ and this fault code P2191 comes up. It refers to lean fuel/air mixture. Any thoughts from anyone?
- x 6953
Re: Fault code P2191 RCZ
Note, this vehicle is being flagged up for a recall / after-sales campaign, so I'd get it booked in at Peugeot. The work will be free and they can confirm what it is for.
As to your failt:
As to your failt:
| Fault Code: | P2191 |
| Description of Fault: | Mixture regulation: Mixture too lean. The "multiplicative" correction of the mixture adaptation is greater than 1,23; No additional confirmation time. Conditions of activation of the diagnostics: The following conditions have to be met: - Engine management ECU in main triggering phase - Deactivation of the fault on certain points (reservoir empty) depending on a threshold of 0,7 |
| Conditions for Fault to clear: | Clearing of the fault provided the "multiplicative" correction is within the range (0,77, 1,23) during a driving phase. |
| Downgrade Modes whilst Fault is active: | - |
| Symptoms: |
| Suspect Areas: |
tomlfc
Thanks for that . Very helpful. I will give it a go!
tomlfc
I went to Peugeot and they said that there is no recall on the vehicle. I was wondering if you had any further information?
