Hi... I have some problems with my Citroen c4 grand picasso 2011...I buy this car from Copart with many, many problems. One by one was fixed, except of one. I have problem with gearbox, and generate error U0304, basically change gear OK but only problem is when change gears the engine is running at high rmp... 3000-4000. I'm thinking is a problem with engine ecu( Continental SID807), I ordered a second hand one from Ebay(with key and BSI module) fitted on car, but no change... Same error same problem. After that I try to find CAN wires from gearbox to BSI, and I see something interesting... Someone else do the same thing earlier, all wires was removed from original position. I suppose some modules, ecu's (gearbox and engine), BSI, BDM was changed by previous owner.
I just want to ask if some one, here, can help me to find original code parts for this car from VIN number?
Thank you!
C4 grand picasso 1.6 hdi 2011 error U0304
Aurelian_ct
- x 6950
Re: C4 grand picasso 1.6 hdi 2011 error U0304
If you can't already find the info you need on the Forum, we do ask for a membership upgrade for official parts data as we are in turn charged for this. It will cover you for future parts requests for up to 2 years, so excellent value.
If interested, links are below, then pop your VIN up.
