Citroen C4 Grand Picasso 2010 Diesel No Fuel Pressure
Grand-Picasso-2010
Unread post by Grand-Picasso-2010 »
Hi
I have a Citroen C4 Grand Picasso 2010 and the car computer says that I have no fuel pressure; the car computer also said I had a turbo over speed fault and this could be related to the no fuel pressure problem
The engine will turn over and I can start the engine using starting fluid (gas in a spray can) but will not continue to run as the car computer says that I have no fuel pressure
1. Does this car have a mechanical and electric fuel pump or just mechanical and what would be the most likely cause for this fault to happen?
2. Has the turbo over speed fault caused the computer to close solenoids and turn off the fuel supply due to this turbo over speed fault, I’m not sure but is this a possibly but maybe someone might know?
3. Has anyone had this issue before? and if so please share your opinion?
Any help will be appreciated, Thanks
x 1506
Re: Citroen C4 Grand Picasso 2010 Diesel No Fuel Pressure
What engine is in it?
Chip73
Unread post by Chip73 »
Will watch this thread. I have a 1.6 hdi diagnosed with low fuel pressure. Mechanic seems to think the High Pressure pump has gone. He can’t fix it due to injury and another garage I asked wouldn’t touch it, stating it had to go to a diesel specialist! Surely it’s just a matter of replacing the pump..? I don’t seem to have turbo issues. Tia for any help.
x 1506
It's something like a 10 hour job.... you'd want to be sure it was at fault before condemning it!!
Chip73
Blimey , quicker to drop a new engine in! :D
Chip73
Are there any easier/cheaper possible causes of low pressure that you would suggest to look at first?
Grand-Picasso-2010
RichardW wrote: 16 Jan 2023, 12:20 What engine is in it?
Hi
The car engine is a 2.0 16V HDi FAP Diesel DW10BTED4 (RHJ)
