3008 smoking after injection change
tomjyoutwit
x 5
Unread post by tomjyoutwit »
Getting lots of smoke after changing the injector 4 on a 3008. Tried two different injectors and same result. Any suggestions? The return rail is a bit loose but injector and feed in seem tight.
Thanks in advance!
x 1911
Re: 3008 smoking after injection change
Unread post by Paul-R »
Does the injector need coding in and did it get done?
tomjyoutwit
x 5
Hi Paul it does but it shouldn’t be smoking out the bonnet like that? I’ve never had that problem. Is it the injector seal?
drayton11
Unread post by drayton11 »
You don't say what engine. On the 1.6 diesel you need a new washer & to replace the stretch bolt. On the 2.0 hdi you need a new washer. Both need the injector coding & then the adaptations reset bin Diagbox, not resetting gives poor running & over fuelling.
