Getting lots of smoke after changing the injector 4 on a 3008. Tried two different injectors and same result. Any suggestions? The return rail is a bit loose but injector and feed in seem tight.
Thanks in advance!
3008 smoking after injection change
tomjyoutwit
- x 5
- x 1929
Re: 3008 smoking after injection change
Does the injector need coding in and did it get done?
tomjyoutwit
- x 5
Hi Paul it does but it shouldn’t be smoking out the bonnet like that? I’ve never had that problem. Is it the injector seal?
drayton11
You don't say what engine. On the 1.6 diesel you need a new washer & to replace the stretch bolt. On the 2.0 hdi you need a new washer. Both need the injector coding & then the adaptations reset bin Diagbox, not resetting gives poor running & over fuelling.
