LED bulbs for rear lights, blinkers, etc
H4wkeye
- x 14
Just curious, did anyone try fitting LED bulbs on the C5 X7 for blinkers, rear positions, stop lights etc? Are there any issues? A friend recently changed his and gotta say it looks really good. But not sure what bulbs he got and if it has to be CANBUS or not?
- x 2355
Re: LED bulbs for rear lights, blinkers, etc
Not rear lights (and so not really answering your question at all, sorry!) But I've got some in my sidelights at the front. Seems to work well and nice and bright. Sideways firing type, so illumination not directed forward.
They do a weird little flash when you unlock the car which was a surprise!
Obviously they make the old fashioned filament bulbs (headlamps) look all the more orange. But I just don't care.
Am looking at a pair of amber LED replacements for the front indicators (as has the stupid HP24W rather than normal PY21W for no sensible reason) but at little concerned I'll pick up a manic flash speed due to the reduced load.
https://www.ebay.co.uk/itm/402213933113
These are what I am considering
H4wkeye
- x 14
Yeah friend installed some front blinker LEDs off Aliexpress and he said the blinkers were going super fast! Is that due to incorrect load? Maybe GiveMeABreak will know more if he reads the thread
- x 5672
I had some as front sidelights. They were very cheap and very blue but lasted ages where the tungsten bulbs lasted only weeks, passed the MOT and were never actually used, only ever drove with dipped headlights.
I have LED reversing lights on the Civic that are very bright, came with 50W ally resistors but they weren't needed. Probably would in a canbus system though.
H4wkeye
- x 14
Is the C5 X7 Canbus or not?
- x 2355
Yes, most indicator circuits need the load of the (normal incandescent) bulbs to flash at the right speed.H4wkeye wrote: 05 Jan 2023, 16:27 Yeah friend installed some front blinker LEDs off Aliexpress and he said the blinkers were going super fast! Is that due to incorrect load? Maybe GiveMeABreak will know more if he reads the thread![]()
Bulb gone or tiny load LED bulbs both tends to give very fast flashing.
Swapped to LED T10 bulbs in the Coupe's side repeaters but normal 21W in front and rear. The loss of the load from the (10W) T10's not significant enough to change the flash speed significantly thankfully.
H4wkeye
- x 14
That is interesting to know, thanks! I wouldn't touch my blinkers yet, just the rear P21/5W and the R5W. On the front I have bi-xenons which are Philips 6000K. The side lights are halogen though.
moizeau
- x 423
If the blinkers blink fast add a resistor. It happens on bikes with the mini indicators that have a lower wattage
Pete
H4wkeye
- x 14
What about the heat? Do the LEDs get too hot or something? Mainly for the ones that are always on at certain times, like rear positions/stop lights.
moizeau
- x 423
no nothing to with heat, although you may need to place the resistor somewhere aerated. It's because LED's use far less power.
Pete
- x 2355
It's funny, but it's the opposite really - LEDs produce very little heat, but need to keep cool to have a long life.H4wkeye wrote: 05 Jan 2023, 17:48 What about the heat? Do the LEDs get too hot or something? Mainly for the ones that are always on at certain times, like rear positions/stop lights.
That's why you see such massive heat sink fins on powerful LEDs - not because they get very hot, but because it is difficult to reject heat to the air with only a small temperature difference between LED temperature and air temperature. But if the little but of heat energy they generate was allowed to build up then the LED would reach a temperature at which it begins to damage itself.
A quick Google (to find a good picture of the fins) has shown it's moved on a stage : these have built in fans to force air cool the heat sink!
https://diversionstores.co.uk/products/ ... 5-hb4-9006
(Shame not road legal
H4wkeye
- x 14
Ah I see. I may try to switch the rear ones soon. What would happen if I put rear blinkers as LEDs and keep the front halogen for now? They'd flash faster?
- x 2355
Yes, the load the flasher circuit sees isH4wkeye wrote: 05 Jan 2023, 18:55 Ah I see. I may try to switch the rear ones soon. What would happen if I put rear blinkers as LEDs and keep the front halogen for now? They'd flash faster?
front + side repeater + rear bulb
Normally:
24W + 5W + 21W = 50W
Note: just looked it up, side repeaters, T10 = 5 W (not 10W as I stated earlier)
So your rears at 21W aren't far off half the total load. So would expect a significant increase in flashing speed if swapped to much lower power consumption LED equivalents. Suppose as a test, uncouple the rear bulbs and see how fast the front ones go, will be something approaching that with an LED in the rear.
Think I've talked myself out of changing the fronts for same reasoning!
H4wkeye
- x 14
Haha, I totally understand ya! Seems like I won't be touching that for now as well. A friend is currently experimenting with it on his C5 X7 so we'll see how he goes.
- x 5672
There are canbus compatible LEDs.
These claim to be anyway, sure to be others.
