Hi all,
Hope someone can help,
I have an issue with the wipers not working on my nemo van, its not the common issue of the linkages as that was done a while ago.
During the cold weather i think the wipers froze to the windscreen and then when i tried to use them again they didn't work.
Ive looked all over for a dedicated wiper fuse but to no avail, and I've checked all fuses in both fuse boxes and they are all good. When i operate the wiper controls I can hear a relay click in the drivers footwell but nothing else happens, the wash still works but no wipers.
Is there another hidden fuse or relay i need to check before removing the wipers and checking the motor.
Ive looked online for a wiring diagram for this and haven't been able to find anything.
Can anyone shed some light on this for me.
many thanks
Paul
2016 Nemo Van
- x 6957
Re: 2016 Nemo Van
You can check Fuse F01 & F03 in the engine Fuse box as these seem to be related to the wipers. It should be near the battery.
Paulsok
Re: 2016 Nemo Van
Hi Marc,
Thanks for the reply, I checked all the fuses in both fuse boxes and all ok.
Cheers
Cheers
- x 6957
Re: 2016 Nemo Van
Maybe the motor is on the fritz from forcing them when they were frozen onto the screen.
Paulsok
Re: 2016 Nemo Van
That’s the next job, to remove the wiper arms and covers etc, then test for voltage at the motor.
I believe it’s 4 pin connection on these so presume the connections are something like-
Earth
12v permanent
12v slow
12v fast
Cheers
Earth
12v permanent
12v slow
12v fast
Cheers
