diagbox fresh install
darbuck
x 289
Unread post by darbuck »
diagbox fresh install not working uninstalled but there are still remaining files i cant remove any help would be appreciated
Darren
darbuck
x 289
Re: diagbox fresh install
I have tried 4 different versions including one off easydiagnostics
Darren
Ross_K
x 110
Unread post by Ross_K »
Here's a bittorrent download link for a virtual machine (VM) version of Diagbox 7:
https://carsoftos.com/index.php?do=download&id=1085
You need a bittorrent client program like qbittorrent to download the virtual machine, and VMWare Workstation Player to run the virtual machine. Everything's configured so you just need to plug in the cable and tell VMWare Workstation to route the USB to the virtual machine
moizeau
x 423
Unread post by moizeau »
The remaining files are locked in the registry and need manually removing. PM Marc explaining which version of windows etc. I don't want to post in public because if the wrong registry entries are deleted the 'puter will need a complete reinstall.
Pete
darbuck
x 289
Hi Lads,
tried it on a different laptop, working perfect. thanks for the advice. Loads of faults, cleared them all. Not too worried about them mostly Comms faults so battery and ECU's disconnected explain most of them. Point is I can talk to it now so happy days. My old diagnostic laptop must be kaput.
Darren
cit-rotti
x 77
Unread post by cit-rotti »
darbuck wrote: 22 Dec 2022, 22:23 diagbox fresh install not working uninstalled but there are still remaining files i cant remove any help would be appreciated
If the usual means do not succeed in making the necessary deletions to reinstall the Diagbox, the easiest way is to reinstall Windows.
Greetings Wolfgang
darbuck
x 289
Unfortunately I have too much other stuff on that laptop I need to get the files and programs off it before I do that and won't have time for that for at least a month. I may have to wipe it long term though.
Darren
x 1939
Unread post by Paul-R »
There is an uninstall program you can run which removes all traces of a Diagbox installation.
darbuck
x 289
Hi Paul, trying to find it. It can wait until after the turkey 🦃 now.🙂
Darren
x 6945
@ darbuck: I have sent you a PM.
