diagbox fresh install
darbuck
- x 291
diagbox fresh install not working uninstalled but there are still remaining files i cant remove any help would be appreciated
Darren
darbuck
- x 291
Re: diagbox fresh install
I have tried 4 different versions including one off easydiagnostics
Darren
Ross_K
- x 110
Here's a bittorrent download link for a virtual machine (VM) version of Diagbox 7:
https://carsoftos.com/index.php?do=download&id=1085
You need a bittorrent client program like qbittorrent to download the virtual machine, and VMWare Workstation Player to run the virtual machine. Everything's configured so you just need to plug in the cable and tell VMWare Workstation to route the USB to the virtual machine
moizeau
- x 428
The remaining files are locked in the registry and need manually removing. PM Marc explaining which version of windows etc. I don't want to post in public because if the wrong registry entries are deleted the 'puter will need a complete reinstall.
Pete
darbuck
- x 291
Hi Lads,
tried it on a different laptop, working perfect. thanks for the advice. Loads of faults, cleared them all. Not too worried about them mostly Comms faults so battery and ECU's disconnected explain most of them. Point is I can talk to it now so happy days. My old diagnostic laptop must be kaput.
Darren
cit-rotti
- x 77
If the usual means do not succeed in making the necessary deletions to reinstall the Diagbox, the easiest way is to reinstall Windows.darbuck wrote: 22 Dec 2022, 22:23 diagbox fresh install not working uninstalled but there are still remaining files i cant remove any help would be appreciated
Greetings Wolfgang
darbuck
- x 291
Unfortunately I have too much other stuff on that laptop I need to get the files and programs off it before I do that and won't have time for that for at least a month. I may have to wipe it long term though.
Darren
OnlinePaul-R
- x 1905
There is an uninstall program you can run which removes all traces of a Diagbox installation.
darbuck
- x 291
Hi Paul, trying to find it. It can wait until after the turkey
now.
Darren
- x 6963
@ darbuck: I have sent you a PM.
