Electrical Question
Doo
(Donor 2022)
x 121
Electrical Question
Unread post by Doo »
Hi folks, re my 2012 Citroën Berlingo ehdi.
The rear load area has a 12v socket, but it's dead until the igniting is on. Can I use diagbox to tell the BSI to switch it to permanently live?
Thanks.
Has anyone seen the plot? :?
x 6955
Re: Electrical Question
No, it's ignition switched.
Doo
(Donor 2022)
x 121
GiveMeABreak wrote: 11 Nov 2022, 18:52 No, it's ignition switched.
I knew that :-D But I imagine that I'll have to run a new wire from the fuse box.
OK. Ta :)
x 1438
Unread post by xantia_v6 »
There may be a more convenient live feed intended for a trailer interface.
Doo
(Donor 2022)
x 121
xantia_v6 wrote: 13 Nov 2022, 06:34 There may be a more convenient live feed intended for a trailer interface.
I'm so dim some days... I fitted a tow bar & electrics (13 pin) and didn't do it the Citroen way (was quoted an arm and three legs :shock: ) so I got a smart relay and did the dirty deed. I tow a trailer and a caravan regularly, so I know they work.
Looks like I'll mostly be drilling a hole and filling it with a 12v socket then. Thanks for waking up my dozy brain :lol:
Reason is, I bought a mag mounted LED spot and it'll be great for winter loading, hitching, chainsawing fallen tree's and such.
