2010 C5 E-brake help!
CaptainFluffy
Hi all! I hope someone can help! I'm getting this. The "P" is always lit. I've changed the handbrake switch but it's still there. I'm unable to manually operate it. I've got a 2010 C5 2.0 Hdi 163 Exclusive. I tried resetting the BSI but all that did was wipe my clock. Helppp! Thank you!!
- x 6955
Re: 2010 C5 E-brake help!
That will need some further looking at to find the issue. There will likely be fault codes generated which will need a suitable diagnostic tool like Diagbox to extract.
This may be a fault with the ESP ECU (which is the master ECU, where the EPB is the slave ECU in the relationship), or purely a fault with the EPB part itself. Either way we would need some fault codes to help further, which you very likely will not get with a generic OBD II code reader.
