Xsara Catalytic converter??
ossian
Unread post by ossian »
I recently bought a Xsara TD I was checking through the specifications on some engine oil I was going to use in a future oil change and it made reference to it being suitable for vehicles with a Catalytic coverter.
3 questions do all zsara TD SX have a converter?
Is there any oil I should stay clear of.
How would the engine oil cause damage to the converter unless there was a fault?
AndersDK
Unread post by AndersDK »
Donno if all (or any) UK imported Xsara TD's have cat's.
But I know for sure that any engine oil available "is suitable for engines with catalytic converter", as the converter certainly do not receive any engine oil - unless the engine is entirely crap [:I]
You should choose an engine oil, which states it's suitable for turbodiesel engines.
ralph
Unread post by ralph »
All Xsara diesels have a cat. But when mine goes pop, I won't be replacing it.
Kowalski
Unread post by Kowalski »
All engines leak a certain amount of oil via the piston rings. If an engine is in good condition this leakage should be minimal (unnoticeable between services). It can take a very small amount of the right (or wrong) substance added to a catalyst to kill it.
ossian
Thanks for the information about the Catalytic converter on my xsara.[8D]. I take it when they expire they are pricey to replace, next question being how long do they last?
paranoid
Unread post by paranoid »
Usually a lot longer than the exhaust,(my 92 rover is still on the original and its on its fifth/sixth exhaust) providing the the car is serviced reqularly, maintained etc.
