identifying wheel sizes..
Agour
(Donor 2026)
x 5
Unread post by Agour »
Hi!
I need to buy a spare set of wheels for using in the winter, and my friend reckons I can get a fairly generic set of steel wheels.
Does anyone know if I can lookup my wheel size, based on the car model? It's a x7 c5 estate...
(Not the tyre size btw, I'm thinking bolt circle diameter and any other dimensions I may need..)
Or, do you know of other wheels that would fit that model? Maybe they used the same wheel sizes on C4's, etc...
Thanks!
Agour
(Donor 2026)
x 5
Re: identifying wheel sizes..
A quick online check says they are 7Jx17 ET32 wheels.. but is there anyway I can confirm this?
Ross_K
x 110
Unread post by Ross_K »
https://www.wheelfitment.eu/car/Citroen ... 2017).html
A lot of wheels will fit in theory, but watch out for the offset!
will tell you how far the new wheel protrudes
I'm wanting a set of C6 wheels myself, but they're few and far between :)
Citroen - C5 (2008 - 2017)
PCD: 5x108
Center bore: 65.1
Offset: 30
Mounting: Bolt - 12 x 1,25
Wheel torque steel: 100 Nm / 74 ft-lb
Wheel torque alloy: 100 Nm / 74 ft-lb
Possible tire sizes:
225/60R16
225/55R17
245/45R18
245/40R19
245/35R20
The minimum tire size may differ per version!
Cars with the same PCD and center bore:
Wheelfitment.eu
Car Year Offset
Citroen C4 Grand Picasso 2013- 47
Citroen C5 Aircross 2017- 42
Citroen C6 2005-2012 32
Citroen Jumpy 2006- 38
Citroen XM 1989-2001 45
DS DS 4 2021- 42
DS DS 7 Crossback 2017- 44
DS DS 9 2020- 44
Fiat Scudo 2007-2014 38
Opel Combo 2018- 47
Opel Grandland X 2017- 42
Peugeot 3008 2016- 49
Peugeot 308 2013- 44
Peugeot 308 SW 2014- 44
Peugeot 407 2004-2010 44
Peugeot 407 Coupe 2005-2009 44
Peugeot 5008 2017- 49
Peugeot 508 2011- 46
Peugeot 605 1990-2000 45
Peugeot 607 2000-2010 39
Peugeot Expert 2016- 46
Peugeot Expert 2 2006-2016 38
Peugeot RCZ 2010-2016 27
Peugeot RCZ-R 2014-2016 27
Peugeot Traveller 2016- 46
Toyota ProAce 2013-2016 42
Toyota ProAce 2016- 46
Volvo 140 1966-1974 40
Volvo 240 1974-1993 25
Volvo 260-262-262c-264 1974-1982 20
Volvo 740 1984-1992 25
Volvo 745 1984-1992 25
Volvo 850 1993-1997 43
Volvo 940 1990-1998 25
Volvo 960 1990-1994 25
Volvo 960 1994-1997 43
Volvo C70 1998-2006 43
Volvo S60 2000-2010 49
Volvo S60R 2003-2010 46
Volvo S70 1997-2000 43
Volvo S80 1998-2006 49
Volvo S90 1994-1998 43
Volvo V70 1997-2000 43
Volvo V70 2000-2007 49
Volvo V70R 2003-2007 46
Volvo XC70 2000-2007 49
if you go with non-standard tyre sizes, use this calculator to make sure your overall diameter stays roughly the same:
https://www.miata.net/garage/tirecalc.html
Agour
(Donor 2026)
x 5
Ross_K wrote: 31 Aug 2022, 15:36 https://www.wheelfitment.eu/car/Citroen ... 2017).html
Image will tell you how far the new wheel protrudes
PCD: 5x108
Center bore: 65.1
Offset: 30
225/60R16
225/55R17
245/45R18
245/40R19
245/35R20
Wheelfitment.eu
Car Year Offset
DS DS 4 2021- 42
DS DS 9 2020- 44
Opel Combo 2018- 47
Ohhh damn, that's a comprehensive listing.. Thanks!
Seems like a lot of wheels have more offset than mine.. Which I guess increases the chance of rubbing 🤔 is there anyway to know what I could get away with?
Ross_K
x 110
Try this page...you can put in the old and new dimensions (and play around with spacer size) to figure out what might fit
https://tiresize.com/wheel-offset-calculator/
Agour
(Donor 2026)
x 5
So I found someone selling c5 wheels from the same year car (but hatchback model) .. Yet they are marked "7jx16ch 5-28"
I guess they should probably fit.. But hard to really know?
Ross_K
x 110
Yeah they should be fine.👍
MelC4
Unread post by MelC4 »
Does 2015 C4 Wheels fit on a 2013 C4.
Jay-Bruce
x 280
Unread post by Jay-Bruce »
All C4's are as far as I can tell, near as damnit the same wheel fitment, save for a mill here or there on offset, so you've got a world of options.
MelC4
OK thank you.
