Hi all, I have C4 1.6hdi 6 speed robot gearbox, year 2007, driven 223000km. Neighbour first had issue with cruise control and then had gearbox fault, esp fault. Gearbox is in failsafe mode and change only to third gear from steering wheel paddles and then up from stick when put to N and back to D. When reading wheels speeds with tester all other speeds are ok but right front shows zero always. ABS sensor and bearing with magnetic thing replaced. Also slaved a new ”should be functional” ABS unit from donor car with same specs but no help. Other notifications that Right tail light and brake light not working, tried new bulbs, no help.
Bearing with abs ring should be good quality due I bought it from good citroen/peugeot spare part shop. Fault codes as follows;
P1394, P0500, U0415, U1213, P0919, C1330 those are related to driving issues. Then there was also
098A, 098B, front side light faults even everything in front was working.
Can you find a wiring diagram for VIN VF7**************[VIN obfuscated, can be read by forum staff] please to measure the wires from abs sensor to abs ecu?
Checked also the big wiring harness behind the battery as stated in one youtube video, didnt took it open 100% until firewall. Left it wrapped 5cm from firewall but pulled all wires quite hard and no wire snapped at least, same from inside and no findings so far. My tester shows in dynamic information all unit voltage and pressures etc ok for my knowledge. Only missing is the right wheel speed. Thanks already if more tips and tricks.
C4 Gearbox fault, Esp fault, no wheel speed Front right
Jassooo
- x 6950
Re: C4 Gearbox fault, Esp fault, no wheel speed Front right
Here are the fault descriptors that I have for you.
Of course, if there is a fault with one or more of the vehicle speed sensors, then the ESP ECU will cut all speed-related features like the cruise control. Furthermore the engine will reduce power as noted with fault P0500.
So you can see there is a knock-on effect whilst you have this issue that will also affect the piloted gearbox.
I would back track on your ABS work and ensure that the ABS speed sensors are all working, the wiring is not corroded and the pug sockets of the connections are all checked for the pin conditions (we have seen this here plenty of times where there is a loose or corroded pin in one of the electrical connectors).
Check all these including the connection to the ESP ECU and Gearbox ECU (again we have seen problems where work has been undertaken in the engine bay and wiring connectors have been damaged or removed and not fitted back properly.
U0415: Fault in the information transmitted by the ECU ABS
P0919: Gearbox fault - The gear cannot be disengaged
P1394: Gearbox ECU fault: Cruise control / speed limiter off request (from the gearbox)
| Fault Code: | U1213 |
| Description of Fault: | CAN communication: ESP torque request error. Request for incorrect torque. |
| Conditions for Fault to clear: | Ignition on |
| Downgrade Modes whilst Fault is active: | None |
| Symptoms: | None |
| Suspect Areas: | CAN network |
| Fault Code: | C1330 |
| Description of Fault: | Front right wheel speed sensor signal fault : Open circuit, short circuit to positive, short circuit to earth. The signal from the wheel speed sensor is monitored by the ESP ECU every 20 milliseconds. Possibility 1: Short circuit to earth Possibility 2: Open circuit Possibility 3: Front right wheel speed sensor: Not supplied Conditions of activation of the diagnostics: Ignition switched on. |
| Conditions for Fault to clear: | The data supplied by the front right wheel speed sensor is valid. |
| Symptoms: |
| Suspect Areas: |
| Fault Code: | P0500 |
| Description of Fault: | Vehicle speed signal : Value received incorrect. The vehicle speed information is higher than the maximum threshold for 1,2 seconds. |
| Conditions for Fault to clear: | Switching on of the ignition. |
| Symptoms: |
| Suspect Areas: |
Doo
- x 121
Having literally gone through some issues with my car, may I suggest you check all connecting plugs & sockets, be they headlamps, tail lamps or at the underbonnet fuse box (which is another computer. Of course, it may well be a dirty connector, but my car couldn't "find' the gearbox because I literally hadn't connected the headlamps!!Jassooo wrote: 02 Aug 2022, 12:01 Hi all, I have C4 1.6hdi 6 speed robot gearbox, year 2007, driven 223000km. Neighbour first had issue with cruise control and then had gearbox fault, esp fault. Gearbox is in failsafe mode and change only to third gear from steering wheel paddles and then up from stick when put to N and back to D. When reading wheels speeds with tester all other speeds are ok but right front shows zero always. ABS sensor and bearing with magnetic thing replaced. Also slaved a new ”should be functional” ABS unit from donor car with same specs but no help. Other notifications that Right tail light and brake light not working, tried new bulbs, no help.
Can you find a wiring diagram for VIN VF7**************[VIN obfuscated, can be read by forum staff]**************[VIN obfuscated, can be read by forum staff] please to measure the wires from abs sensor to abs ecu?
So if you have a break in the wiring, the comms wont get through.
The ABS plug connectors are generally good, but if the wire gets trapped at can chafe, which would create a grounding fault or they could be touching each other which would create a similar fault.
We had an issue a few years ago when the fuse connectors in the engine bay had been subject to trees dropping tree stuff
Hope this helps
Has anyone seen the plot?
Jassooo
Re: FIXED. C4 Gearbox fault, Esp fault, no wheel speed Front right
Hi thanks from the tips, so eventually firtsly replaced the ABS sensor from big car part supply chain store here in Finland and that didnt fix it. Then replaced the bearing with magnetic sensor ring, no fix. Dig through wire bundles and finally today had time to measure the wires from ABS unit plug to ABS sensor and all ok 1.9 ohms. So finally went again to very good small Citroen Peugeot part shop were the guys have been selling parts for 25 years and asked for a 100% sure working ABS sensor and they sold me OE sensor. Installed that and it bloody fixed the issue! Wasted hours due non good aftermarket sensor!
Please buy always OE or known good aftermarket parts for your own sake
Thanks from the assistance!
Jassooo
Well its not fixed anymore. After 10 days, gearbox fault and same what was before came back. Same fault code, R front wheel ABS sensor and wheel speed missing. Checked the left abs sensor just in case if my reader is crazy. On left was lots of dirt on top of the magnetic ring, cleaned and swapped the R and L sensors but fault still on right. I guess this car is going bother someone else now, teying to sell it for spares or something. Start to believe that something can be wrong in BSM also and those engine fuse/relayboxes are not manufactured anymore.
gwest
- x 20
All very discouraging. Re: Other notifications that Right tail light and brake light not working, tried new bulbs, no help.
Were the lights actually working and the warnings just phantom ones?
Doo
- x 121
The only possibility could be the wheel bearing isn't O/E quality or the connector plug is dirty (which would create a high resistance) or a wire has chafed between the plug and the under bonnet computer fuse box.Jassooo wrote: 04 Sep 2022, 20:23 Well its not fixed anymore. After 10 days, gearbox fault and same what was before came back. Same fault code, R front wheel ABS sensor and wheel speed missing. Checked the left abs sensor just in case if my reader is crazy. On left was lots of dirt on top of the magnetic ring, cleaned and swapped the R and L sensors but fault still on right. I guess this car is going bother someone else now, teying to sell it for spares or something. Start to believe that something can be wrong in BSM also and those engine fuse/relay boxes are not manufactured anymore.
We had a Laguna 2 in a work (back in 2010) with a new rear wheel bearing and it didn't re-set the ABS light. I told the boss that it HAD to be O/E or the Laguna would throw up a fault code... Sure enough, the guy returned next day, I fitted one from the dealer and the light extinguished by the time I had reversed off the ramp & driven to the reception door
Doo
- x 121
This can be caused by grot on the bulb cradle connectors! Even a tiny bit of white on the silver connection will create high resistance and fool the system into "thinking" a bulb has blown.gwest wrote: 05 Sep 2022, 08:06 All very discouraging. Re: Other notifications that Right tail light and brake light not working, tried new bulbs, no help.
A pain it the hoop, but can be fixed with a cardboard nail file or switch cleaner & the end of a small flat screwdriver to scrape the grot away (MAKE SURE lights are switched OFF or you'll blow a fuse if you short out the connectors).
Jassooo
Thanks from the brainstorming, I measures the ABS sensor wires from the sensor to ABS module and both of the wires were 1,9 ohms so I didnt start to dig in more. The system worked for a two days after replacing the OE sensor, then had intermitten fault again and then 7 days later all same faults came back and never had those cleares again. Swapped left and right sensors but fault stayed on the right. Tail lights I never checked again.
Just sold the car last sunday ”as is” and told about the faults and history etc and was surprised how many wantet to buy it. So not more my problem
Neighbour bought DS4 2012 1.6eHdi so lets see what that will in future
