Tailgate window won't open c5 estate mark 2
kevino
x 4
Unread post by kevino »
Hi guys need a bit of help. The window part of the tailgate won't open. No response when button is pressed. Is there a common failure point for this?
I want to go peacefully in my sleep just like my granddad, not screaming like his passengers
jamescarruthers
x 47
Re: Tailgate window won't open c5 estate mark 2
Unread post by jamescarruthers »
Hey. Yes, this is a common failure and can be resolved with the introduction of a new grounding wire on the tailgate. I haven’t done it myself but the previous owner of my sister’s C5 showed me his modification, which he’d read about in here and it is still working years later. It looked easy enough to do.
1987 Volvo 480 ES
2006 Citroen C6 3.0 petrol Exclusive
x 3298
It is also possible that the issue is down to water ingress in the switch. I had this on my first and second C5, and replacing the switch solved it (but the switch is around £50! :shock: )
kevino
x 4
Yikes, that's a bit much for a switch. I wonder if i can run an electrical test and take switch apart?
x 5689
Try this thread for more info.
