1.4Hdi Crank seal issues
Johndoc90
Hi guys, thanks for the add. Wondering if aanyone can help me here. The main crankshaft seal failed contaminating the clutch. New clutch and seal fitted, problem arrisen again.
I have the box out and about to fit another seal, it is possible I messed up with the first one, but I would be greatful for any tips in fitting it, eg use of lube or sealers. The other consideration is the the crankcase pressure, I have taken of the cover and the diaphram in the breather looks ok, but, would this cause backpressure anyway? The engine has only done 75K and regularly serviced so i don't suspect ring wear. although cant rule it out. TIA
Doo
- x 121
Re: 1.4Hdi Crank seal issues
If you get a seal from PSA (comes in a black square packet) it's the type you do not oil! Fit it on and the seal shrinks with the build up of heat when the shaft spins.Johndoc90 wrote: 23 Jul 2022, 15:50 Hi guys, thanks for the add. Wondering if aanyone can help me here. The main crankshaft seal failed contaminating the clutch. New clutch and seal fitted, problem arrisen again.I have the box out and about to fit another seal, it is possible I messed up with the first one, but I would be greatful for any tips in fitting it, eg use of lube or sealers. The other consideration is the the crankcase pressure, I have taken of the cover and the diaphram in the breather looks ok, but, would this cause backpressure anyway? The engine has only done 75K and regularly serviced so i don't suspect ring wear. although cant rule it out. TIA
If you use a standard spring seal, oil it liberally and ensure it is square as it goes on.
However, in both instances, check the end of the shaft isn't contaminated with rust or gouges from previous damage.
Has anyone seen the plot?
Johndoc90
Thanks Doo that is really helpful
