radio rt6 does not work properly
Bite2013
I updated softwear and navigation, radio rt6 does not work properly
OnlinePaul-R
- x 1938
Re: radio rt6 does not work properly
Did it work properly before you did any of the updates?
What version was the firmware before? What did you update it to?
Bite2013
Yes before i update work properly.
Before was 2.7.0
And now i upgrade to 2.86
Before was 2.7.0
OnlinePaul-R
- x 1938
Where did you get your copy of 2.86 from?
How did you install it? From a CD or from a USB stick?
Which did you install first, the firmware or the map?
Did you check between the two updates to see if the radio worked?
