radio rt6 does not work properly
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
Bite2013
Unread post by Bite2013 »
I updated softwear and navigation, radio rt6 does not work properly
x 1940
Re: radio rt6 does not work properly
Did it work properly before you did any of the updates?
What version was the firmware before? What did you update it to?
Bite2013
Yes before i update work properly.
Before was 2.7.0
And now i upgrade to 2.86
x 1940
Where did you get your copy of 2.86 from?
How did you install it? From a CD or from a USB stick?
Which did you install first, the firmware or the map?
Did you check between the two updates to see if the radio worked?
