No reverse
Paul H 69
No reverse
comeing home today i had a engine fault warning so after my tea i went to have a look. no codes came up on my OBC reader thing. then i started it.it said engine faul stop and wont engage reverse to get off my drive. i rolled back a bit and it whent forward ok but wont go backwards. please help. VIN VF7**************[VIN obfuscated, can be read by forum staff]
- x 6950
Re: No reverse
Your issue is going to be that a generic fault code reader won't read the more advanced constructor codes. You have a piloted manual gearbox and these are notoriously difficult to troubleshoot, having a large number of fault codes. You really aren't going to make progress on this unless you get it properly diagnosed with Diagbox. I can almost guarantee there will be faults logged, so you need to be able to provide those in order for some idea of the issue.
Have a look at our list of members who have offered Lexia / Peugeot Planet / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
Paul H 69
Re: No reverse
Thanks for the quick reply Marc. will cheack that out.
