C5X7 MM RNEG2 rebooting all the time, issue!
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
M3D
Unread post by M3D »
Hi Folks!
Hope you are all ok.
I know the issue is not a new but still issue.
MM rebooting all the time dealer said need replace MM but you know its approx. 2k€ :-D just found info about replacing sd card try to make copy of old sd card but its not help, can some one help me to solve this Problem.
Thanks a lot
x 6945
Re: C5X7 MM RNEG2 rebooting all the time, issue!
It’s no good copying the old card as you’ll just be copying any file corruption faults over....
Try following the advice listed on the RT6 forum (where I’ve moved this topic to) on replacing the MicroSD card. Use the Mirascripts info to copy your user data off first though.
Failing that, you may have a hardware fault and may need the unit repaired or replaced.
M3D
Thanks mate
