Hi Folks!
Hope you are all ok.
I know the issue is not a new but still issue.
MM rebooting all the time dealer said need replace MM but you know its approx. 2k€ just found info about replacing sd card try to make copy of old sd card but its not help, can some one help me to solve this Problem.
Thanks a lot
C5X7 MM RNEG2 rebooting all the time, issue!
Moderator: GiveMeABreak
- GiveMeABreak
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow - x 5645
Re: C5X7 MM RNEG2 rebooting all the time, issue!
It’s no good copying the old card as you’ll just be copying any file corruption faults over....
Try following the advice listed on the RT6 forum (where I’ve moved this topic to) on replacing the MicroSD card. Use the Mirascripts info to copy your user data off first though.
Failing that, you may have a hardware fault and may need the unit repaired or replaced.
Thanks mate
