Xantia 1.8 16valve 2000.
started it this morning, it caught then promptly stopped, will turn over but won't catch.
I've checked the fuel, that's getting through, checked the coil pack, didn't look bad but got a new one on order.
Checked the plugs,they seemed ok but dry though it was a few hours after I turned it over, did turn it over with the plugs out and did see a fine mist come out of the holes, tried it with the MAP sensor disconnected, nothing.
Don't have a Lexia and can't move the car.
I'm in Royal Wootton Bassett, Wilts.
Any ideas greatly welcome
Xantia Non Starter
peter306
- x 60
Xantia Non Starter
Citroen GSA flat4 engine written off
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen Xantia 1.8 gone
Citroen Xantia 1.8 still living now 148 k
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Re: Xantia Non Starter
Changed the coil pack, still not starting,turns over strongly but that's all.
Anyone in the Swindon, Chippenham or Royal Wootton Bassett area with a lexia I would be very grateful if you would pop over and plug it in.
Thanks Peter
Thanks Peter
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
- x 1489
Have you got a spark? Does the rev counter flicker when cranking? Does it sound normal when cranking / is the cam belt intact? If the belt is OK, I'd be inclined to stick a new crank sensor in it if they're not too dear.
citroenguy
- (Donor 2021)
- x 76
Are the injectors firing? Any wetness om the plugs immediately after a turn over session?
Does it run on easystart?
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
peter306
- x 60
RichardW, rev counter doesn't move, how do you check the spark, it's a 4 in 1 coil pack, is it just take them all out and rest the plugs on a metal part of the head, cranking fine, cam belt is fine.
Citroenguy, just turned it over, the plugs are dry.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Hello again, new crank sensor fitted, no change, rev counter not moving, no smell of fuel. turning over nicely. any more thoughts. I reckon either something well hidden or the engine ecu as possibilities
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
citroenguy
- (Donor 2021)
- x 76
What brand of crank sensor was fitted?
Some can be duff from new, even bosch ones
citroenguy
- (Donor 2021)
- x 76
Is the ECU getting crank signal?
Lexia might be able to pull live data
handyman
Might be worth checking the fuel pump & fuel rail pressure regulator, as I found that issue recently on a 1.8 16V. It did run but with an extremely weak mixture which meant it ran very hot.
If you check these items by disconnecting the fuel pipes, make sure you have an adequate vessel to catch the fuel.
First check would be to see if you can hear the pump running with the ignition on.
peter306
- x 60
Hello Handyman. Already done that, took the return pipe of just after the valve, nice load of fuel coming through.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
peter306
- x 60
Hello again, The crankshaft sensor was the problem, thanks to RichardW for pointing me in the right direction.
Also thanks to citroenguy for posting that video, turns out the new one was a Bosch and was wired the wrong way round.
Car is now running and off to Yorkshire tomorrow.
Citroen BX 1.4 gone
Citroen BX 1.6 gone
Citroen BX 1.4 gone
Citroen BX 1.6 gone
admiral51
- (Donor 2026)
- x 391
Cracking result enjoy Yorkshire
