Lexia Diagbox Newbie
Just taken a punt on used Lexia3/PP200/Diagbox V7 on eBay. I've read a few posts on this forum and I was just wondering if it's fairly user friendly?
- x 3393
Re: Lexia Diagbox Newbie
Not really - it was never released to the public. What you are purchasing is a 'modified' version to allow DIY / Professionals access to PSA's bespoke diagnostic hardware and software. Their technicians are trained on how to use it and have regular bulletins on features and updates that you and I will not have access to.
If you are new to all this then I recommend you read the important pointers I put together on this thread:
viewtopic.php?t=60600
Thanks again Marc, some very useful tips there. I'm only planning some simple fault diagnosis on the parking system, but still all good info.
OK. Failed at the first hurdle!
Installed Diagbox and updated to 7.83 (not on the internet).
Took laptop to car, disconnected the internet, plugged in the VCI, green light came on.
Then nothing.
No vehicle information and the Global Test & Faults Journal are greyed out.
If I click on the Citroen banner i get ' Data Access Problem'. but if I click the tick twice, it disappears.
Any clues?
Then nothing.
Any clues?
- x 3393
It has likely deactivated as a result of being internet connected at some point.
You will need to restore the licence file that you should of backed up after installation.
In future, it is essential to keep the network / WiFi adapter switched on, but disconnect any software internet connections to your home router / public WiFi AND make sure that they do not automatically connect when in range of a hotspot.
Restore the licence file? I don't remember that being mentioned in the installation instructions! Looks like its an uninstall / reinstall then!
- x 3393
Copy the licence file from C:\AWROOT\BIN\FI\APPDIAG.SYS after the installation and after it restarts which should be at version 7.02 of Diagbox. Copy the APPDIAG.SYS files from the directory and store it safely so that you can copy it back to the same location later it later if Diagbox deactivates.
Did a full uninstall using - 'Diagbox uninstall and cleaner'.
Then re-installed in flight mode, so no chance of activation.
Connected the laptop to the car with no networks connected, but not in flight mode.
Opened Diagbox and................ still nothing!
How can I tell if it's deactivated?
P.S. thanks for the licence tip. I'd already re-installed, by the time I'd read your post though.
- Donor 2022
- x 181
I think I had to delete a registry folder before reinstalling but Marc will advise better. I'm using Win7 32 bit.
I assumed the removal software did all of that?
