So I'm the lucky
I have diagbox which I regularly use for maintenance.
Now I got a dead adblue tank ...
fault code U029E 87 permanent
ECU EDC17C60? test shows "not communicating with denox system"
DENOX system relay control test OK
NOX sensor heating test OK
UREA reservoir heating test FAIL
UREA pipe heating test FAIL
UREA injector control test FAIL "urea solution pressure out of range"
The part number is PSA 9818559280
My question is: if I buy a replacement tank with the same part number - will it need online telecoding at the Citroen dealer or will the ECU accept the new tank and U029E 87 go away?
Hope this makes sense
