P1199 Citroen c4
KostasGMS
P1199 Citroen c4
P1199can anyone help with this damage ?? thank you very much
- x 6950
Re: P1199 Citroen c4
You will need to supply the vehicle VIN as fault codes are specific to the engine management system used.
KostasGMS
- x 1061
P1199 = Fuel circuit : Incoherence on the reserve fuel pressure (Nearing no fuel).
What is the problem you are having with the car? not starting? poor running? just a warning light?
- x 6950
Here is the fault code descriptor:
| Fault Code: | P1199 |
| Description of Fault: | Fuel circuit : Incoherence on the reserve fuel pressure (Nearing no fuel). The pressure measured in the fuel high pressure common injection rail is lower than the reference value for 800 ms even though the electrovalve is open to the upper limit. The following conditions have to be met - engine running - Low fuel level |
| Conditions for Fault to clear: | Ignition switched on |
| Downgrade Modes whilst Fault is active: |
| Symptoms: |
| Suspect Areas: |
KostasGMS
starts normally and after 300-400m stops
- x 1061
My first port of call for any fuel pressure related fault code would be to replace the fuel filter if you have not already done so.
- x 1061
Might be worth giving some more info on the fault & anything you have already done or checked to try and fix this, It may save people giving advice or information that isn't relevant?
