P1199 Citroen c4
Post Reply
KostasGMS
My Cars: Citroen c4
P1199 Citroen c4
Post by KostasGMS »
P1199can anyone help with this damage ?? thank you very much
C5 MK I 2.0 HDi SX Wicked Red
C15 Romahome White
XM 2.0 SX Polar White
CX 20 Polar White
GS 1220 Geranium Red
GS 1000 Cedreat Yellow
x 5708
Re: P1199 Citroen c4
Post by GiveMeABreak »
You will need to supply the vehicle VIN as fault codes are specific to the engine management system used.
KostasGMS
My Cars: Citroen c4
Post by KostasGMS »
My Cars:
x 729
Post by wheeler »
P1199 = Fuel circuit : Incoherence on the reserve fuel pressure (Nearing no fuel).
What is the problem you are having with the car? not starting? poor running? just a warning light?
C15 Romahome White
CX 20 Polar White
x 5708
Here is the fault code descriptor:
Fault Code: P1199
Description of Fault: Fuel circuit : Incoherence on the reserve fuel pressure (Nearing no fuel). The pressure measured in the fuel high pressure common injection rail is lower than the reference value for 800 ms even though the electrovalve is open to the upper limit.
The following conditions have to be met
- engine running
- Low fuel level
Conditions for Fault to clear: Ignition switched on
Downgrade Modes whilst Fault is active:
  • Engine stopped
  • Irreversible deactivation of the vehicle cruise control (Need to switch the ignition off and then on, in order to make the function available again)
  • Irreversible deactivation of the vehicle speed limiter (Need to switch the ignition off and then on, in order to make the function available again)
  • Activation of the cooling fan at fast speed
Symptoms:
  • Jerking/stalling
  • Lack of power
  • Starting problem
  • Absence of automatic stopping of the internal combustion engine (Vehicle equipped with "stop and start")
Suspect Areas:
  • Running out of fuel
  • Clogging of the fuel filter
  • Low pressure fuel circuit
KostasGMS
My Cars: Citroen c4
Post by KostasGMS »
starts normally and after 300-400m stops
My Cars:
x 729
Post by wheeler »
My first port of call for any fuel pressure related fault code would be to replace the fuel filter if you have not already done so.
KostasGMS
My Cars: Citroen c4
Post by KostasGMS »
new fuel filter
My Cars:
x 729
Post by wheeler »
Might be worth giving some more info on the fault & anything you have already done or checked to try and fix this, It may save people giving advice or information that isn't relevant?
Post Reply
